Re: Oil Weight Makes A Difference!!!
Posted by Steven@nd on December 03, 2002 at 11:27:03 from (165.234.131.150):
In Reply to: Oil Weight Makes A Difference!!! posted by scotty on December 03, 2002 at 11:23:29:
Yep, our 544 won't start when it is below zero with 30 weight oil, even if you plug it in! But now with 10W oil it fires right up without being plugged in down to about 10 degrees.
Have noticed the difference on other tractors too, when the weather quickly turns cold in the fall.
Post A Followup
: Re: Re: Oil Weight Makes A Difference!!!
