Re: Re: Farmall H coil woes
Posted by RayA on December 08, 2002 at 17:46:48 from (66.64.31.181):
In Reply to: Re: Farmall H coil woes posted by The Red on December 08, 2002 at 13:17:31:
thanks for the reply. Will the newer coils fit in and bolt on the old mounting clamp? The newer clamp wont compress enough to put two bolts in where it secures to the distributer. May have to secure with one bolt I guess. Also, do I need to install a resistor for it or is there a resistor somewhere else on the tractor? Dont remember seeing one. Thanks again,RayA
Post A Followup
: Re: Re: Re: Farmall H coil woes
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
