Re: Re: Re: Farmall H coil woes
Posted by joe on December 09, 2002 at 05:18:43 from (66.43.207.226):
In Reply to: Re: Re: Farmall H coil woes posted by RayA on December 08, 2002 at 17:46:48:
No need for a resistor. Resistors are put in when you have a six volt system, that you change to twelve volt, and you don't want to have to change out the coil, distributor parts, etc.
Our 400 has a larger coil than original, eg. it is only held on by one bolt and the bracket won't fit both the holes at the same time (same situation as yours). I assume that it must be a newer coil too.
Post A Followup
: Re: Re: Re: Re: Farmall H coil woes
