Re: The pressure is on
Posted by Ira from Penna. on December 14, 2002 at 13:03:16 from (64.12.97.13):
In Reply to: The pressure is on posted by mk on December 13, 2002 at 08:30:33:
mk,
I had trouble with a tractor that sat for a few
years and I was working by my self. I took one
of our tractors and put a belt on the pulley you
have to criss cross it so it turns over the
engine in the right direction set the brakes on
both tractors engage the pulley system on the
tractor that doesn't run, use your clutch on the
good tractor turned the engine over for about 4 or
five minutes it started to fire then disconnected
the belt then was able to use the starter, just
took the belt to turn the engine over fast enough
to seat the rings and flush the old fuel through.
Hope this helps a little.
Post A Followup
: Re: Re: The pressure is on
