Re: Farmall 140 electrical a puzzle
Posted by Jamie on December 15, 2002 at 16:40:59 from (24.61.140.171):
In Reply to: Farmall 140 electrical a puzzle posted by Hugh MacKay on December 15, 2002 at 14:46:49:
Hugh,
My 140 is just a little bit later than yours (23,000 or so). It definitely came as a six volt system, with positive ground. What you describe doesn't surprise me. Before I converted to 12V, I had to jump my 6V battery frequently. I always jumped from a 12V battery, and it would start quick. The 6V just never seemed to have enough power to crank it over, especially when it was cold out. My guess is that you have a 6V battery and that it is shot. You should seriously consider upgrading to 12V, negative ground with electronic ignition before you put much time and money into your 6V system. You'll be much happier in the long run. Good luck.
Post A Followup
: Re: Re: Farmall 140 electrical a puzzle
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
