Re: Battery draining
Posted by o4terry on December 16, 2002 at 07:11:05 from (67.251.139.78):
In Reply to: Battery draining posted by Mac on December 16, 2002 at 06:39:21:
One thing you might try. Hook up a test light between your battery post and cable after the cable has been removed. If you have something pulling current, the light will stay on. Usually you can find the problem area by then pulling fuses. I think you only have one fuse so you will have to disconnect various items, ie lights etc. till you see the light go out. Hope this helps.
Post A Followup
: Re: Re: Battery draining
