Re: Charging a 6 Volt battery
Posted by Steve - IN on December 16, 2002 at 09:59:09 from (12.222.17.160):
In Reply to: Charging a 6 Volt battery posted by MattM on December 16, 2002 at 08:37:37:
MattM,
An old battery might not appreciate that approach.
If you have a second 6 volt battery - wire two in series and charge them as 12. -- or --
Short of going out and buy a 6 volt charger, put about 4 to 5 ohms of ballast resistor(s) in series from the charger. Make sure the resistor(s) handle at least 24 watts ( 12v x 2A = 24 watts). Measure the voltage drop before you start - you should end up with a little less than 7 volts. This setup should work for the battery on a consistent basis, and should be cheaper than buying a new charger.
Also, if you're in no hurry at all - a 6 volt AC to DC adapter running about 300 milliamps might do it in 10 to 15 days at a price of 7 or 8 bucks.
Steve
Post A Followup
: Re: Re: Charging a 6 Volt battery
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
