Charging a 6 Volt battery
Posted by MattM on December 16, 2002 at 08:37:37 from (130.76.96.19):
I just got a used tractor that is supposed to run but the 6 volt battery is dead. Does anyone know if it is OK to use the 2 amp setting on a 12 volt charger to put some life into the battery? I realize this is not the right thing to do on a regular basis, but I was wondering if I could get away with it this time and not harm the battery.
Any input is appreciated.
Post A Followup
: Re: Charging a 6 Volt battery
