Re: Charging a 6 Volt battery
Posted by jake on December 16, 2002 at 10:21:02 from (213.28.162.104):
In Reply to: Charging a 6 Volt battery posted by MattM on December 16, 2002 at 08:37:37:
it won't harm anything, as long as you see that the voltage on the battery doesn't raise a lot higher than 7 volts.
A good trick that i have used several times is to put 10-15 meters of some iron wire in series with the ground lead, to reduce the charging current. Had to do this because battery was completely empty, and the thermal switch didn't stay on in my battery charger. it's only necessary of course if you keep blowing fuses.
Post A Followup
: Re: Re: Charging a 6 Volt battery
