Re: Farmall A questions(seat spring and hydraulics)
Posted by Haas on December 17, 2002 at 14:17:16 from (166.72.245.199):
In Reply to: Farmall A questions(seat spring and hydraulics) posted by Mark from Genoa on December 17, 2002 at 09:29:05:
Don't know about the seat springs. On the hydraulics, add a reservoir and a pump. You can rig up a bracket to attach the pump so it runs off the generator belt. You'll have to get a longer belt so it will go around both the generator and the new hydraulic pump pulley. You'll have to also have hoses and a control valve of some kind and a cylinder to lift whatever it is you have in mind. It's gonna be a fairly expensive deal. I have a shop mule that is rigged up like that for the snow plow.
Post A Followup
: Re: Re: Farmall A questions(seat spring and hydraulics)
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
