Re: Re: Need help, crankshaft pulley
Posted by Reddog on December 21, 2002 at 11:14:12 from (66.103.239.240):
In Reply to: Re: Need help, crankshaft pulley posted by Larry Ks on December 20, 2002 at 17:59:02:
Thanks for the reply. As mentioned in previous posts the end of the crankshaft is drilled & tapped but there was no bolt in it and I also had tried hitting the puller bolt with hammer, no luck. My puller was custom made for me by a guy at work for this one purpose. The bar that bent was what the puller bolt went through. I have replaced the bar with a 1.5" thich walled square tube. Hopefully this won't bend as easy. I won't get a chance to try it until Monday.
Post A Followup
: Re: Re: Re: Need help, crankshaft pulley
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
