Water or hydraulic fluid?
Posted by CNKS on December 25, 2002 at 11:14:43 from (207.178.96.213):
Replaced the head gasket on my C because of low compression on #2 and #3. Had head milled because someone earlier had pried it off with a screw driver and gouged it. No visible cracks in head. Machine shop guy says valves are ok. Tractor runs fine except for a small amount of smoke out the oil filler (blow by). No exhaust smoke (neither blue or white) and no evidence of oil in the water. Ran tractor about an hour yesterday with new oil and antifreeze. When I unscrewed the crankcase plug this morning and let the oil dribble, oil is milky for an ounce or two and then clears up -- no green antifreeze color. Same as before I changed the head gasket. Is this water or hydraulic fluid (hytran)? Will the hydraulic fluid mix uniformly with the oil, i.e., all milky, or will it settle to the bottom like water? If so next step is to replace seal in hyd pump, but I'm still not sure about the head gasket and/or O rings at bottom of sleeves (I've heard the o-rings don't just dribble, when they go, they go). Viewed through the spark plug holes all cylinders have moisture of some kind in them -- can't reach it to see if it's water--have not checked it hot, will visible condensation form overnight? There was (apparently) a little antifreeze in a couple of the cylinders when I removed the head, but that could have come out of the head when I removed it. By the way what is the correct torque? I torqued and re-torqued to 65 lbs ft as per IT manual. IH service manual doesn't say and www.weberstractorworks.com says 80. Sorry for the long post.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
