Re: Re: Farmall 140 coil.
Posted by Hugh MacKay on December 26, 2002 at 07:28:22 from (209.226.106.33):
In Reply to: Re: Farmall 140 coil. posted by gene b on December 26, 2002 at 04:31:49:
Thank you gene, really shouldn't matter which way that coil is hooked up it being nothing more than a transformer. I have discovered this am that I have drain on battery soon as I couple it up, switch off. I removed the starter, then starter switch and discovered someone has decided to dispence with the two plastic shields inside the starter switch. That may or may not be creating short. Hard to tell when assembled. I guess I should couple system leaving starter unhooked to see if I still have short elsewere. What are the chances of the regulator causing short considering battery was hooked neg ground for a time? This tractor is a 1963.
Post A Followup
: Re: Re: Re: Farmall 140 coil.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
