Farmall A Oil Pan
Posted by Rockhound on December 26, 2002 at 17:09:02 from (209.34.2.72):
Is there a trick to dropping the oil pan on a Farmall A? I wanted to take the oil pan off to clean out the sludge I suspect is there. After purchasing a new gasket, I went home, drained the oil, and started removing the oil pan bolts. The bolt in the front posed a slight problem, as it won't clear a bolt in the front axle directly underneath it. I'm sure it is backed out all the way, so I figured on just sliding the oil pan a little sideways to remove it. I removed all the other bolts, and broke the seal on the front and sides, but the back of the oil pan won't budge. I didn't want to force it in case there was a clip or some kind of retainer holding it in place. Can anyone tell me if this is the case, or is the lip of the oil pan just jammed in tight against the bell housing? I'd be grateful if someone can tell me the answer. Thanks!
Post A Followup
: Re: Farmall A Oil Pan
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
