Re: Farmall A Oil Pan
Posted by EZ on December 26, 2002 at 19:09:27 from (216.211.7.37):
In Reply to: Farmall A Oil Pan posted by Rockhound on December 26, 2002 at 17:09:02:
I concur with Farmer Bob,
I did my '44 A last year,
the timing cover has to be removed.
Have an eye which bolts go where when re-installing the pan, as there are a couple of different lengths. If you try putting one of the longer ones back into a hole where a short one was, you will certainly strip the threads in the hole.
Good luck.
P.S. Once you get the pan off you can shine a light up inside and see the condition of your sleeves, crank, etc...
Post A Followup
: Re: Re: Farmall A Oil Pan
