Re: H radiator close to steering shaft
Posted by Richard C on December 27, 2002 at 06:34:33 from (64.233.66.182):
In Reply to: H radiator close to steering shaft posted by John on December 26, 2002 at 18:49:05:
Mine did the same thing. I looked and looked and scratched my head and finally got it to fit better. Your tractor should have a support thats kind of U or V shaped that bolts to your thermostat housing then bolts to both sides of your radiator. If this is not bent or warped then that should align the top of the radiator. Then unless your metal is bent up it should get you pretty darn close to where it should be. Hope this helps and makes alittle since.
Richard C
Post A Followup
: Re: Re: H radiator close to steering shaft
