Re: Farmall 1066 low power
Posted by Hugh MacKay on December 28, 2002 at 06:13:45 from (209.226.106.65):
In Reply to: Farmall 1066 low power posted by Brandon on December 28, 2002 at 05:05:53:
Have you checked the turbo? Pump may need a professional inspection. I had a 10 when new, back then most of the 10s were cranking 150 hp+. For want of a better word 9s seemed then to be the lame duck, not so much that they didn't measure to ratings. It was more a case of 10 exceeding its ratings. I am talking of tractors as they came from factory, untampered with.
Had problems once with a Cat 3306, after much searching it turned out to be an air leak on pump. After $1,500 had been spent, a 65 cent gasget around inspection cover for timing. Look for the simple things first my advice.
Post A Followup
: Re: Re: Farmall 1066 low power
