Farmall Tractors Discussion Board |
Re: Re: Re: need wiring diagram for Intern. model M tractor
Posted by Bob M on August 31, 1999 at 04:58:42 from (192.232.120.194):
In Reply to: Re: Re: need wiring diagram for Intern. model M tractor posted by Phil Wise on August 30, 1999 at 16:44:44:
The original switch and wiring has the rear light on bright in both the D and B switch settings. Only the front headlights get dimmed on D. The dimmer coil gets pretty hot (though not red) even with two stock headlamps on dim. Can't figure why the factory provided a dim setting on the light switch. On bright the stock headlights are marginal at best...
Post a Followup
