A turn of the crank and the A purrs to life!
Posted by mk on December 31, 2002 at 11:19:28 from (12.25.53.124):
Well I guess it wasn't quite that simple. I finished reassembling my '47 A on Christmas eve (Q&D rebuild, rings, bearing, valve job etc). So I went and filled the radiator, installed the plugs, added gas and started cranking. The best I could do was a sputter, with the engine just puffing a little smoke on each crank... So I grabbed a can of either and sprayed a little in the hole in the manifold right above the carb (has a little plug in it if that helps), and she fired right up, for a few second... Well did the same thing two or three times and pretty much determined that I had a carb issue. Now give that this is the carb I just rebuilt for my other A (the 41, read below), I went and found the one that was on the 47 (which has been sitting in kerosene for about a year and a half). Drained the kerosene out, installed it, and 3 cranks later it sputtered to life. Given it took a few more cranks and some fiddling with the choke to get it to run, not all that bad. I must say that having an engine you rebuilt fire up for the first time is quiet a thrill! So, now all the goodies, great oil pressure, the cylinder pressure is back up to where is should be, and more importantly even, and not a puff of blue smoke in sight. So after retorqueing the head I took it for a spin around the farm, I must say it felt like a victory lap! So back to that faulty carb. It was on a 41 A that a friend gave me. I have been trying to that old girl going for a while. The carb was really gummed up so I bought a rebuild kit and did the usual clean and replace. When I installed it on the tractor it did the same thing, just little puffs of smoke. I assumed this was due to the low pressure on the number 2 and 3 cylinders (stuck rings I hope). Well now that I know that the carb isn't helping, where should I go next? Sounds like it's starved for fuel to me. I didn't reset the float when I did the rebuild, and it seemed a little on the low side (that is it would shut off quicker), could that be the problem? Maybe I'm asking to much, that is having two running tractors that I worked on. :) Thanks! mk
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
