Re: A turn of the crank and the A purrs to life!
Posted by doug on December 31, 2002 at 14:57:58 from (65.234.208.148):
In Reply to: A turn of the crank and the A purrs to life! posted by mk on December 31, 2002 at 11:19:28:
MK low float could very well be the problem. When you cleaned the carb before rebuild, did you soak it in the carb solvent that removes EVERYTHING? Before going to drastic measures, try poking a straw from a WD40 can through the bowl drain hole and see if the float is not stuck. If my A sits for a while and the carb drains, the float sticks. The only way I've found to open it is to tap lightly on the bowl and if that doesn't work, use the WD40 straw. Good Luck.
Post A Followup
: Re: Re: A turn of the crank and the A purrs to life!
