Re: Just bought a cub
Posted by Phlogiston on December 31, 2002 at 20:04:28 from (65.129.72.57):
In Reply to: Just bought a cub posted by bradford253 on December 31, 2002 at 16:12:28:
On the left side as you sit on the tractor, you will see a small square head plug on the side of the transmission. Pull this out and let it drain until it stops. You have too much fluid inthe transmission. The noise you hear is normal. Hy-tran in the gear box is fine. 90 wt. is ok too and will quiet down the rear some. The leak on the final drive is due to a bad seal in the side of the transmission. Not a bad job to replace. Use a sling to reinstall the final drive so you don't distort the new seal. Place the new seal so that it rides on an unworn portion of the axle shaft. Make sure you block the front of the tractor so it won't roll when you jack the back end of the tractor and take off the final drive.
Phlogiston
Post A Followup
: Re: Re: Just bought a cub
