Re: TD-9: tractor won't start on gas
Posted by Bill L Md on January 02, 2003 at 16:46:17 from (68.55.41.86):
In Reply to: TD-9: tractor won't start on gas posted by Roger A. on January 02, 2003 at 16:32:06:
Roger , was having similar problems with my cub ,eventualy had to replace the carb quite salty,did you check to see if your carb is sucking air around the housing by spraying a carb cleaner on the carb while you have it running for those few seconds,if so it should run and run smooth, this will take three hands.After a rebuild kit and alot of cussing I had to get a new carb, housing was bad.
Post A Followup
: Re: Re: TD-9: tractor won't start on gas
