Re: Grain Drill
Posted by Lloyd on January 03, 2003 at 09:37:56 from (66.43.215.98):
In Reply to: Grain Drill posted by Avery on January 03, 2003 at 08:23:31:
In order to raise the drill, you have to be rolling. You have to pull the rope attached to the clutch and then let go right away (if you hold on too long, you drop it right back into the ground). The drill should start to plant when it is lowered. My drill has two cluches, one for each half of the drill.
Post A Followup
: Re: Re: Grain Drill
