Re: 666 hydro
Posted by Robbie on January 04, 2003 at 20:45:20 from (208.54.197.208):
In Reply to: 666 hydro posted by Paul Szepi on January 04, 2003 at 18:58:37:
First off what you have is a Hydro 70 cause International didnt make a 666 Hydro it was called the Hydro 70 and if the transmission is out then you are looking at around $4,000.00 for parts and labor and then you will have a completely rebuilt transmission and if you change the filter and oil regularly in the transmission you will get 6,000 hrs out of the transmission before it starts slipping again and maybe more.
Post A Followup
: Re: Re: 666 hydro
