Re: Re: Re-installing the Crank Pulley
Posted by George Willer on January 05, 2003 at 18:44:38 from (66.242.44.135):
In Reply to: Re: Re-installing the Crank Pulley posted by Paw Paw Dave on January 05, 2003 at 17:52:31:
When you draw it on, be sure to use threaded rod screwed in as far as it will go. Use washers and spacers as necessary and pull it on with a nut. This avoids the risk of stripping the thread in the crank.
George Willer
Post A Followup
: Re: Re: Re: Re-installing the Crank Pulley
