Re: Re: Re: Re-installing the Crank Pulley
Posted by Brian on January 05, 2003 at 18:56:54 from (24.114.185.3):
In Reply to: Re: Re: Re-installing the Crank Pulley posted by George Willer on January 05, 2003 at 18:44:38:
I can't remember what exactly the front of the crank looks like. I know there are the "groves" or whatever you want to call it where the crank goes in. If I put washers over this will they sit square? should I use a huge washer and apply pressure on the "front face" of the whole pulley ?
Thanks for all the replies !
Post A Followup
: Re: Re: Re: Re: Re-installing the Crank Pulley
