Re: Rebuilding Motor - Too much lube ?
Posted by Shovelman on January 06, 2003 at 18:31:54 from (24.151.89.245):
In Reply to: Rebuilding Motor - Too much lube ? posted by Brian on January 04, 2003 at 09:14:07:
Brian,
I have always had good luck with using the heavier assembly lubes on the cam & followers, rocker arms, etc., especially if the engine is not going to be started right after rebuild. Otherwise, I use a good grade of motor oil for assembly and then pressure-prime the system using a "pig", just before initial start-up. A Chapin style garden sprayer can be easily modifed and connected to a gauge or other pressurized oil port in the block. I usually feed 2 to 3 quarts of oil into the system this way before starting. Just be sure that everything is perfectly clean - sprayer, hose, fittings, oil, etc. before you start. I bought a new sprayer for less than $20. just for this purpose. Insures a good start and considering what rebuilds cost today, it is cheap insurance. Good Luck! Scott
Post A Followup
: Re: Re: Rebuilding Motor - Too much lube ?
