Farmall Tractors Discussion Board
Re: Re: Electrical Question
Posted by Theman on September 01, 1999 at 07:24:49 from (204.149.23.2):
In Reply to: Re: Electrical Question posted by ltf in nc on September 01, 1999 at 05:44:39:
Just a minor clarification: Connect the resistor between the coil and the points. If it is a 12-volt coil, it should receive 12-volt power.
Everything between the resistor and ground will be 6 volts, give or take. If you had a 6 volt coil you would need to connect the resistor between your ignition switch and the coil.
Post a Followup
: Re: Re: Re: Electrical Question
