Re: fuel bowl on Farmall H
Posted by Tom on January 10, 2003 at 02:45:58 from (198.108.134.152):
In Reply to: fuel bowl on Farmall H posted by Yellott Canby on January 09, 2003 at 20:00:48:
Yellott, I experienced the same after changing the bowl on our M. What I discovered was that the casting was not drilled and machined completely and was collecting sediment; therefore, restricting fuel. The sediment that was collecting in the casting should have traveled to the bowl. I took it off and (yes, your sleeve will be saturated with fuel when you do this!) passed a drill through and removed the obstruction. This was last spring when I was fitting ground and no recurrence of the problem. Tom
Post A Followup
: Re: Re: fuel bowl on Farmall H
