Re: Hydraulic dilema
Posted by D webber on January 14, 2003 at 04:31:25 from (216.106.40.169):
In Reply to: Hydraulic dilema posted by TonyG on January 13, 2003 at 15:33:40:
I had a similiar problem with mine , and found it was a bypass problem. Right on the righ side , bottom of the touch control head (remove battery box) you will find a 5/16 th's allen head . take this out and put in a flat blade screwdriver and back out a retainer . behind this you will find a small falt washer like thing with a real small hole in it with a screen ( some have a screen and some dont) you will need a self holding screwdriver or a real small magnet to get this piece out. Clean this and see if it makes a difference. You will need a straight pin to check the hole to make sure it's not plugged . I hope this helps
D webber
Post A Followup
: Re: Re: Hydraulic dilema
