Re: Trailer wiring
Posted by Farmall 300 on January 18, 2003 at 07:43:59 from (64.12.97.13):
In Reply to: Trailer wiring posted by K.B. on January 17, 2003 at 19:04:15:
You may have a problem in your adaptor. The 6 and 7 pin connectors have 3 wires for the lighting, 1 wire for ground, and 2 additional wires-1 for brakes and 1 for 12volts charging the trailer battery (if you have a camper). The 7th pin on the 7pin is for backup lights on large trailers. It sounds like your 12volt charge line (on all the time) is being connected to your brake 12volt line and locking up your brakes. If you do a search online, you can get the pin connection standards diagrams and with a simply 12volt test light or volt meter determine if the problem is at trailer, tow vehicle, or adaptor connections. Good luck.
Post A Followup
: Re: Re: Trailer wiring
