Re: Re: Re: Snapped Stud on Block
Posted by Bill Smith on January 20, 2003 at 09:36:04 from (63.147.130.75):
In Reply to: Re: Re: Snapped Stud on Block posted by The Red Barron on January 19, 2003 at 19:53:20:
In order to weld you are correct. What you are welding to does need to be grounded. Welding is a simple but interesting process. You strick an ark with the rod (or wire when using wire welder) and you must maintain that ark to weld. Touch what you are welding with the rod/wire and the ark will be lost becuase of a direct short. Electrical current through that ark is what creates a high level of heat and creates the burning process of the rod or wire. (Of coarse you have to have flux on the rod or most wire welders use gas so the rod/wire will burn.) Without that ark or flux/gas it is highly unlikely you will weld the stud to the block in between the threads. If it twisted off it is deffinately a tight enough fit in there to carry the ground current with no problem. As for bearings and welding something close to it, it is a matter of the grease getting hot and burning, leaving the bearing dry when the welding is done. That or the bearing must be clean and welding allows the bearing/grease to be contamenated with slag/dirt which will cuase the bearing to shell out over time if you run it like that. Otherwise I don't understand your bearing senerio. Bob has good idea on this version of the welding process. Basically accomplishes the same thing as welding a nut on. It creates a couple of advantages. 1 you can use the peice of flat iron as the wrench when you are done welding, and 2 the flat iron may aid in controlling where the slag goes if you are trying to catch it from getting into unwanted places.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
