Re: Northern Radiator for H
Posted by CNKS on January 20, 2003 at 18:42:42 from (207.178.96.211):
In Reply to: Northern Radiator for H posted by K-Mo on January 20, 2003 at 08:30:37:
Installed one on my C. It fits fine, maybe a slight misalignment with the radiator filler, but not objectionable. I did have to grind out the front bolster a little to prevent the lower tank from rubbing when I tightend it down. Are you sure they sent you the right radiator? A quarter inch difference in the holes is lousy quality control. Can you but pads underneath the radiator to raise it -- haven't looked at the one on my H. Although I bought my Northern from Carter and Gruenwald, I later found a website that listed all of Northern's radiators (cheaper than C&G), you might check that unless that's where you found your radiator to begin with.
Post A Followup
: Re: Re: Northern Radiator for H
