Northern Radiator for H
Posted by K-Mo on January 20, 2003 at 08:30:37 from (167.142.167.33):
Has anyone installed a Northern radiator (CR9523) on a H?
When I installed one, I found the top grille mounting holes were about 1/4" too forward and caused the grille to jam against the radiator neck. Since these are threaded nut inserts, there is more to it than just moving the holes. Even if I move the holes, the radiator neck will still have to be pulled up aboout 3/8" to get the cap on. I am afraid that pulling up on the neck may crack the weld.
The holes on the original radiator are about 7/8" from the rear of the radiator frame. The holes in the Northern are about 1-1/8".
Has anyone had success installing Northern radiators?
Post A Followup
: Re: Northern Radiator for H
