Re: Re: Brakes on a '53 Super A?
Posted by Al on January 22, 2003 at 08:19:40 from (65.161.226.217):
In Reply to: Re: Brakes on a '53 Super A? posted by John_N on January 21, 2003 at 12:43:56:
As mentioned, the LH is probably weak due to leaking trans seals lubricating the brake band. When you replace the seals, make sure there is no groove worn in that shaft or the new seal will leak.
Have seen a lot of SA's with squeaky brakes, esp. on the right. I wonder if having the drums trued up on a lathe would help? Also if the tractor is used infrequently the drum might rust, making the brakes "grabby" and noisy. Just thinking out loud.
Al
Post A Followup
: Re: Re: Re: Brakes on a '53 Super A?
