Re: Farmall A vs. Farmall Cub
Posted by Haas on January 22, 2003 at 11:38:48 from (166.72.245.14):
In Reply to: Farmall A vs. Farmall Cub posted by Nick in SC on January 22, 2003 at 11:24:19:
The Cub is not capable of much heavy duty work. If you expect it to replace your Ford 9N, forget it. The A (I'd suggest a Super A because it has the hydraulic touch control unit) is twice as much tractor as the Cub. If you are just going to use the Cub to cultivate with, it will work OK, but be aware that transport is a problem if your plots are not close about. The Cub has only a 3 speed transmission with a top speed about half the A in 4th gear.
Post A Followup
: Re: Re: Farmall A vs. Farmall Cub
