Re: Super M power steering
Posted by Farmer Bob on January 22, 2003 at 18:07:11 from (67.3.38.157):
In Reply to: Super M power steering posted by Tim Malin on January 22, 2003 at 17:28:09:
Tim, It's your tractor and you should do whatever you want with it and to it. I believe you will find that if you add the power steering unit to the tractor, you will probably leave it on permanently. The way to have your choice is to get another shaft from a bone yard as you said. Then, you would have both shafts for changing if you wanted.//FB
Post A Followup
: Re: Re: Super M power steering
