Re: Going through the M?? $$$?
Posted by Keith on January 25, 2003 at 20:45:46 from (67.233.82.247):
In Reply to: Going through the M?? $$$? posted by Ed on January 24, 2003 at 10:45:05:
Ed, 2 summers ago, I redid 1. We done it at my friends auto repair shop. He charged me 300.00 for help and space. It was there 2 weeks. We did everything that you said, except we turned the crank. I only honed the cylinders as they miked out fine. I spent 2200.00 total on parts and repair. The head was a big part of that and the purchase of a new carb. I had the unleaded gas valves installed as well. I never 1/2 do anything. I figure its better to spend more now than do it over. On the cylinders, I have 1 that apparently does not stay sealed. As on occassion , it will use a quart of oil. I have been told that the 30 wt oil will not properly seat / seal the rings. So if I dont sell it before summer I am going to try a different grade of oil. The oil use is not bad because I use it to run a roto tiller. And I use it rather extensively . Hope this helps. Feel free to email if you have questions or run into problems. maybe I can help. Will gladly do so.
Post A Followup
: Re: Re: Going through the M?? $$$?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
