756 IHC gas ELIMINATE TA
Posted by lenray on January 26, 2003 at 10:51:29 from (208.153.180.24):
I have a 756 gas tractor where the TA seems to be in a bind when put into DIRECT DRIVE the forward position.
Have discussed this on this forum not sure if it is the MCV or the torque--the tractor works fine when the lever is pulled back--in the slower more powerful pulling position. This problem happened all at once nothing leading up to the problem that I could tell.
Pulled the hyd. filter it was comepletely plugged and the bypass screen was blow off on one corner.
I bought this tractor used and neglected to find this problem as I only use the tractor about 10 hours per year--no excuse for this neglect on my part.
HERE IS MY QUESTION----if there is a problem with the TA I am going to replace the TA with a shaft and eliminate the TA. WHERE can I get this replacement part????
len
Post A Followup
: Re: 756 IHC gas ELIMINATE TA
