Re: rear axle question: 72 Int'l 1800 Loadstar
Posted by Bob on January 28, 2003 at 12:26:56 from (66.231.124.6):
In Reply to: rear axle question: 72 Int'l 1800 Loadstar posted by doug vose on January 28, 2003 at 08:10:36:
The Eaton 2 speed shifter uses light weight #10 or #20 motor oil in the screw case of the actual shifter. There is a rubber boot that acts as a seal of sorts to keep the light weight oil in the shifter, and keep the 90 gear oil out of the shifter. Often, this boot gets torn or damaged, letting the heavy gear oil get into the electric shifter, which causes it not to work in cold weather. You may instead have an electrical problem with the shifter switch, the wiring to the axle, or with the limit switch in the shifter itself, not to mention the mechanical things that could be wrong with the actual 2-speed gear mechanism.
Post A Followup
: Re: Re: rear axle question: 72 Int'l 1800 Loadstar
