Re: 1950 IH Super A
Posted by Haas on January 31, 2003 at 06:52:18 from (166.72.245.117):
In Reply to: 1950 IH Super A posted by Clipper on January 30, 2003 at 19:50:32:
For pushing snow, a front mounted blade is by far the best. If you mid mount the blade, you have to push the front tractor wheels through the snow first. The force required for that will greatly reduce your capacity to plow the snow. If the blade is mounted in front of the wheels, the wheels just roll on the cleared path.
Post A Followup
: Re: Re: 1950 IH Super A
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
