Re: Re: Real Question, Whats a 230 worth?
Posted by Haas on January 31, 2003 at 06:59:47 from (166.72.245.117):
In Reply to: Re: Real Question, Whats a 230 worth? posted by CNKS on January 30, 2003 at 19:18:18:
Don't run the pump unless it is hooked up to the reservoir that has oil in it. Running the pump dry will ruin it.
Post A Followup
: Re: Re: Re: Real Question, Whats a 230 worth?
