Re: farmall (a) fan shimming ?
Posted by Bill Hires on February 01, 2003 at 10:24:31 from (128.206.231.178):
In Reply to: farmall (a) fan shimming ? posted by Jon Mirgon on February 01, 2003 at 09:19:21:
The sheave will go on when it is heated before sliding it on the crankshaft. It does not need to be so hot it ruins the seal, an oven set on 400 degrees works for me. Cool it as soon as it is in place. Be sure the crank and key are clean and well lubricated. I use a wear sleeve on the sheave if there is a deep groove worn in it. I would not use shims on the fan shaft.
Post A Followup
: Re: Re: farmall (a) fan shimming ?
