Re: Bushhog shear pin
Posted by Michael Soldan on February 01, 2003 at 15:55:27 from (216.46.130.25):
In Reply to: Bushhog shear pin posted by Rodger on February 01, 2003 at 10:38:52:
Roger , set up your PTO with a good shear connection and make sure you use soft bolts that will shear. Several years ago I was brush hogging and sheared a pin, I grabbed a bolt out of the tool box and went on..problem was the bolt was hard steel and didn't shear the PTO drive gear stripped instead...cost me about $500 to get it working again..better to shear a pin than smash your tractor...Good luck from MIke in Exeter Ontario
Post A Followup
: Re: Re: Bushhog shear pin
