F-20 noise
Posted by Randy Santifer on February 01, 2003 at 21:36:27 from (66.109.132.27):
Pistons came loose on stuck engine very easy but as i turn it over I head a clunk sound from around the magnito every 1/2 turn of crank. I have never had a magnito tractor is this normal. I have a cylinder with bad pits in it Can a sleeve be bored or is it easer to replace sleave and piston together. any help gladely accepted Randy
Post A Followup
: Re: F-20 noise
