Re: Need some help on a Farmall 100
Posted by bill b va on February 02, 2003 at 16:33:16 from (209.240.198.63):
In Reply to: Need some help on a Farmall 100 posted by John on February 02, 2003 at 14:18:29:
john.. i suspect your battery is being drained by the alternator . if possible find a local mechanic to test for current flowing back through the alternator when the engine and switch are off if you are not able to test it your self. in the mean time you can prove the above by disconnecting the wires to the alternator over night . depending on the type of alternator a switch or diode may be needed to prevent the back flow of current through the alternator ....possible carb problems ... #1 float level not set correctly . when the bowl is near full fuel should shut off just like your commode... #2 float hanging on sides of bowl not letting it shut off fuel .#3 float needle valve not seating fully allowing fuel to flow past it .once again a good local mechanic that knows carbarators can fix the problem .
Post A Followup
: Re: Re: Need some help on a Farmall 100
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
