Re: Need some help on a Farmall 100
Posted by Bob M on February 02, 2003 at 19:15:05 from (66.66.123.133):
In Reply to: Need some help on a Farmall 100 posted by John on February 02, 2003 at 14:18:29:
John - 3 possibilities for the battery running down: 1 - Battery is bad, 2 - Alternator is wired wrong, or 3 - Alternator itself is bad.
First try removing the ground cable from the battery after you shut down. If the battery stays up overnight you know the battery is OK. Then disconnect the two auxiliary (terminals #1 and 2) wires at the alternator, leaving only the wire to the BAT terminal connected. If the battery now stays up overnight, you've got a wiring problem. If the battery still goes down, the problem's gotta be in the alternator.
As for the carb problem, it shouldn't leak gas - running or stopped. Sounds like the dealer botched the rebuild. Surging/hunting could be caused by this. Could also be due to the mixture adjustments being outta whack, or to a stiff governor to carb linkage.
Post A Followup
: Re: Re: Need some help on a Farmall 100
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
