Re: Farmall H won't stay running
Posted by Chuck on February 04, 2003 at 09:08:14 from (216.170.58.10):
In Reply to: Farmall H won't stay running posted by Steve on February 04, 2003 at 07:16:33:
Remove fuel line at carb and check for full flow coming from the tank.If there is very little flow remove sediment bowl assm from tank and clean out the standpipe going into the tank as they fill up with crud and restrict the flow.
Post A Followup
: Re: Re: Farmall H won't stay running
