Re: H felt washer
Posted by Farmer Bob on February 04, 2003 at 20:51:07 from (67.3.10.42):
In Reply to: H felt washer posted by Rod on February 04, 2003 at 18:11:47:
Its possible the brass washers go on the studs that stick up through the valve cover. Check the size of them for that spot. (The washers go on after you put the valve cover on and before you screw the nuts down onto the studs.)
Post A Followup
: Re: Re: H felt washer
