Re: M cracked block?
Posted by scotty on February 05, 2003 at 09:41:46 from (199.231.49.128):
In Reply to: M cracked block? posted by Josh on February 05, 2003 at 09:18:17:
Josh,
I know its after the fact now but what I generally do is drain the motor dry and mix equal parts of antifreeze and water and then mix and reinstall. Just a thought. If your temp only got down to 10 degs and you even only had a little bit of antifreeze in motor you should be alright.
scotty
Post A Followup
: Re: Re: M cracked block?
